Ford Ranger MT 15 build
i'm guessing you have the 95 amp alty which is usual for a ranger, if a 130 amp alty would work for what your running get one from a explorer
my ranger has a 130 //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif hehehe
and what amp is powering the sub op?
autotek mm3000
yes, it's a 90A. are the explorer alternators a direct bolt on? i've never looked into that before... my friends 97 expo just bit the dust and i might be able to rob it off his....
autotek mm3000
mine was just direct bolt up lol.... ive seen some that needed a little modding.
make sure its the 3g alternator unless you want to swap housings, i have a mechman high output from an explorer f/s if you want to swap the housing on it since its a 4g its like e3 r 4 bolts
grassroots
needs car audio rehab
grassroots
ATL
truckcap22
