For the last time, PLEASE: clipping does NOT blow speakers/subwoofers
Holy running in circles batman. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Heat. Is produced by clipping. Will cause failure. Any questions? //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Heat isn't produced by clipping, electricity passing through a conductor with resistance causes heat.
Refer to my post on page 10 as to how it becomes higher than 1500w.
ahhhh, i see now.
that would make sense why the tone used which was -6db resulted in 1500w clamped. the music was not clamped (because i would think its too hard to try to get actual numbers from fast paced music) so i just assumed it wasnt clipping. i guess it could very well be that the music was at a different level than -6db, which caused the amp to pour out a lot more power and clipping, all the while i assumed it was the act of clipping that was causing the speaker to reach thermal limits, when in actuality it was the power caused by the clipped signal that was doing it, which of course, wouldnt be 1500w anymore. my post probably is worded weird and ****, but trust me, i finally understand you guys
wow, i just had an epiphany lol
but this bring up a new topic, although technically its not really the clipping that is blowing the speaker...the excess power is a result of it no?
in my eyes, i would still consider clipping guilty by association
Clipping causes more heat? Is that better for you? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
And yes I am well aware of the bibles posted regarding soft clipping, tube clipping, blah, blah.
But I can sit here and blow a speaker by clipping the shit out of it. There simply is no ifs ands or buts about it.
Its the heat. Thus the term thermal failure. Yes it can be caused by clipping but not always.
Its semantics. People will argue circles around each other saying basically the same thing but just dont get the point.
well yes, its the heat, which is coming from the excess power.
//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif just playing with ya. i know what you mean.
That's what we've been saying //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The reason this is so hotly debated is because it is not fully understood. You can have a clipped signal which results in over powering the speaker and thermally destroying the voice coil. You can also have a clipped signal that results in a bad sound, but zero bad effect to the driver.
There is plenty of square wave material in music.
This is the reason I will never say clipping hurts a driver. There is more than one scenario that will result in clipping, and at the same time will NOT have any physical effect on sub/speaker.
i agree. i was in that boat.
on another note, i usually assume people power 2000w subs with 2000w amps, so i think saying "make sure the amp doesn't clip cause it can kill it" is the right thing to do. at least in my eyes.
PV Audio
The Vision of Sound
PV Audio
Indy
mcsoul
