You can't have both at the same time.just something that will be loud as **** but also have a nice clean sound quality. and i generally listen to rap and rock
your system will only sound as good as its weakest link. and Bose just doesn't cut it. and if you keep the OEM nav system get a line driver or whatever the hell those things are...indeed i got bose speakers and the navigation system that came with the car
He may not have the Bose setup. If he has the premium package then it has the bose. Also, you are using the factory HU without oem integration then you have to tap into some wires BEFORE the Bose amp (if you have it).your system will only sound as good as its weakest link. and Bose just doesn't cut it. and if you keep the OEM nav system get a line driver or whatever the hell those things are...
I would definitley upgrade, otherwise your subs will overpower the front stage. You will need baffles, or spacers as the g35 guys call them and they should have them on ebay. Make sure you check the depth you have to work with before buying speakers. Roll your window down first when you do this. Also, there is a piece of metal as reinforcement that limits the depth. If that wasn't there, you wouldn't have to worry so much about depth.so should i keep the bose speakers or no
