Focal K2p excursion ftw video
Right now I have my rainbows set to the following on my 9887 active:
Low- 63hz @ 12db
Mid-L set to 63hz, 12db
Mid-H set to 5khz 12db
High- 5khz 12db
RIght now I do not have my gains set 100% correctly...but pretty close. Im going to eventually set them with a DMM to get 90-100w per door for the mids, and probably 50w or so for each tweet.
I have found that when I turn the crossover down on the tweeter, it gets harsher.
Both the Mid and tweets should be 4 ohms right? Not having the passive crossover doesnt change anything right? So if you could clarify what you meant that would be awesome.
Kris
Most component sets use 6 or 8ohm tweeters...I actually think the TN52 in the K2P set is a 6ohm, which really isn't a big deal.
Low- 63hz @ 12db
High- 5khz 12db
Yeah those crossover points are really high compared to most active setups. I always try to find a tweeter that I can crossover pretty low because my tweeters are in the a-pillar and I want to keep as much of the stage up high.
But if it sounds good to you, then it's all good. I believe the K2P set crosses the mid and tweet at 3.15khz, but with just a 12db/oct slope. If your 9887 has 24db/oct crossovers you could probably drop the tweeter to 2.5khz.
mobeious
what does 0hz feel like?
mobeious
Bartow, FL
krisfnbz
