First time metering....147.5 today
Nice Job! Did ya fix the hurt woofa?
I reconed it this past thursday and threw it in that night. Played it alittle. After about 3-4 hours of some break I threw some power at it and I thought one of the dang spiders ripped again. So before the comp I decided to say f it and played it full tilt for a few songs. Sure enough I think the other spiders needed to break in as the top spiders break in first. Never made a bad noise during the comp and everything seems great now.
Now I just need to think of some new plans/setup. Gonna make a box tuned to around 40ish hz and see what that may do. Burp box maybe. I'll be seeing a 150;)
must be the box because it was pretty stuck on peaking at 40-41hz
x2 yeah it was stuck on 40-41 hz
it may be nice that I can actually build a daily box where it peaks.
Hey profundus-sanus, were you the guy helpin me on that last metering? Appreciate it. I had a blast
yep, i **** with introductions //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Nice job for your first comp bro... Good score, but that setup definately has a good amount more in it. Play around w/ sum new boxes and i'd suggest sum 8" or 10" aeros.
my 10 pvc thats in the setup right now was hard as hell to find...not to mention pricey$$$
I'm gonna try some more boxes tho.....lots of port area (20 sq in/cube) and tune a box to around 42 hz, maybe build a box with interchangeable ports
Try to get the 10" Sonotubes (tubes used to pour concrete) and fiberglass/resin the inside to harden it. Alot cheaper than 10" PVC.
I know, I called everywhere within 100 miles,and for some reason 10" is hard to find in michigan...
it should be well worth the wait, when you do get a chance to hear it.
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
hell I'm sure I could come down to you another time, maybe at the taylor show too
wouldn't mind to do some more playin around and tuning.
I'm thinkin of gettin a used term lab for use up here
da box king
da box king
Portland, MI
da box king
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
