First time alarm install
btnhfan
Hail to the King Baby!!!!
Okay so I have some questions and need some advice.
I have a Viper 5002 that I plan on putting in my 99 civic.
How long approximately will it take? I am also adding a glass break sensor instead of the shock sensor, and a backup battery for right now.
For the keyless entry, do I need to use relays when I connect it or can I just tap directly in?
What are all the aux ports for on the brain? Expandability I am assuming.
Thats it for now.
99 civic uses negative trigger door locks, so you are not going to need any extra relays, they are already in the car from the factory.
The time it takes to install is going to depend on how much time you want to put into it. Do you just want to connect wires and have it work, or do you want to take factory wire looms apart and mask the install, solder wires, mount the brain behind the glove box or under the center console, putting an alarm under the dash and just T-tapping wires isn't a very effective installation.
My creto - if you are going to do it, take the time to do it right the first time. If you don't have the time, pay some one else to do it. If you don't have the money, then safeguard your car in other ways (IE - remove door lock rods, remove trunk release rods, etc etc.)
Not to threadjack, but I have a 2003 accord. Are the locks the same way you described for me as well? No additional relays? I am removing most of my interior to do sound deadening, so it's a good time for me to do it. Any other additional materials that need to be purchased?
the accord will have negative trigger door locks as well located on the passenger side iirc.
werd.
Yea I plan on doing it right the first time. I am hiding the brain in the rear of the car behind a panel, therefore making it near impossible to get to. I know I am going to have to extend all the wires and everything.
maybe it is just me, but I wouldn't follow that word for word, if it is pasted all over the internet, a thief could easily steal your car. Having your alarm install pasted for everyone to see isn't an effective alarm install.
BE CREATIVE!!!!
First alarm I did took me all day. But that was taking my time and being careful. Why not use both glass and shock sensors? Add a couple mini piezos in the vents as well //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Found this for download.
The 12 Volt Resource Guide. I've seen this on eBay for sale and now you can download for free!
http://rapidshare.com/files/49519175/12_Volt_Resource.rar.html
Click on free download.
After you are done rename the file by removing the .html at the end.
Then extract all the files into a new folder and burn to CD or save on your hard drive.
All 1979-2007 Vehicle Wiring Diagrams on CD-ROM
12 Volt Resource Mobile Installation CD-ROM
Version 4.2
12 Volt Resource™ Aftermarket Installation CD-ROM v4.2 is designed to be the ultimate reference tool for anyone planning to install an aftermarket Security, Remote Start, Keyless Entry, Audio or Video device in their car, truck or SUV. From initial concept through deployment - The resources on this disk will guide you so the job gets done right the first time.
* Designed to simplify car audio, video and security installations
* Tells you all of the wire colors, locations and polarities needed for installing car alarms, remote starters, keyless entry, navigation, head units, speakers, mobile video systems, and subwoofer enclosures
* Includes step-by-step installation instructions
* This is the same information that is used by professional installers, but designed to be suitable for both novice installers and pros alike
* Updated twice a year (upgrade discount if you have an earlier version)
* 100% satisfaction guarantee
NOTE: Vehicle wire colors typically stay the same until the manufacturer introduces a new body style. For example: If you need a wiring diagram for a 1991 Honda Accord, you could use the same diagram from any 1990-1993 Accord because it wasn't until 1994 that the body style changed.
All of the vehicle wiring information provided by 12 Volt Resource has been verified. If your current-year vehicle is not on the list above and you know the body style has not changed, chances are you can use the wiring information from the previous year.
Vehicle Wire Color & Installation CD-ROM Contents
12 Volt Resource™ Aftermarket Installation CD-ROM v4.2 is truly the most valuable & complete vehicle installation reference guide available today. Take a look below and see for yourself how much invaluable information we have to offer.
This CD-ROM contains a full installation database with vehicle wire colors for nearly every make and model vehicle manufactured from 1979-2007. Also included are Vehicle Specific Notes for Integrating and/or Bypassing Factory Alarms, Transponders, and Immobilizes (when applicable) such as General Motors Passlock I, Passlock II, PASSKEY III, VATS, Ford PATS.
Simply insert this CD-ROM into any Windows, Macintosh, or Linux based computer or laptop and enjoy instant access to this fantastic installation tool. Fully plug and play, the only software required is Adobe Acrobat Reader, a full version of which is included on every CD-ROM we sell (12 Volt Resource™ is a licensed distributor of Adobe Acrobat Reader).
Section #1 - Security Installation
* Full vehicle security/remote start wire color database illustrating wire colors and locations for nearly all make and model vehicles manufactured from 1979-2007. Connections include Ignition #1, Ignition #2, Ignition #3, Accessory, Brake Light, Tach, Parking Lights, Headlights, Power Lock & Unlock, Interior Dome Light, Horn, Trunk Release, Factory Alarm Disarm.
* Highly in-depth vehicle security, remote start, and keyless entry installation instructions
* Vehicle Specific Notes for Integrating or Bypassing Factory Alarms, Transponder systems or Immobilizes including General Motors Passlock I, Passlock II, PASSKEY III, VATS, Ford PATS
* Instructions for bypassing the clutch on manual transmissions
* Alarm Modules, Alarm Sensors & Triggers
* Installation Notes, Tech Tips & Trouble-Shooting Guides
* Accessories & add-ons
Section #2 - Audio & Video Installation
Full vehicle audio & video wire color database illustrating wire colors and locations for nearly all make and model vehicles manufactured from 1979-2007. Connections include Constant 12V, Switched 12V, Ground, Illumination, Dimmer, Remote Amplifier Turn-on, Power Antenna, FR/RR/FL/RL Speakers.
* Vehicle-Specific Speaker Size Charts & Detailed Application Guides
* How-to instructions for building custom subwoofer enclosures
* Volume Calculators
* Accessories & Add-Ons
* Windows & Macintosh based subwoofer box modeling software
Section #3 - Installation Basics
* Safety Information
* Basic & Advanced Wiring Connections
* Diodes, Ohm's Law, Relays, Resistors
* Installation Glossary
Section #4 - Recommended Installation Tools
* Basic Tools
* Test Equipment
* Power Tools
* Pneumatic Tools
//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
NEW link:
http://rapidshare.com/files/51762424/12_Volt_Resource.rar
Got another question. Should I put the antenna on the front or rear glass?
Rear has tint on it, front does not.
Also I assume I have to program both remotes? Can someone explain how it is done for both the lcd and the other one. I guess the other one is for valet or something.
btnhfan
btnhfan
CT/ GA Tech, Atlanta
btnhfan
vegang
vegang
