First Post!!! HELP~
etl45
HI! wassup all~~~
i just got into the audio stage so im kinda new to all this and in the dark!
i just recently purchased a kicker zx750.1 amp! here are the specs if you need them~
Model: ZX750.1
Class: D
Power (watts) mono: 750 @ 2 ohms
Remote bass control: yes
Length (in., cm): 14-11/16, 37.3
Height (in., cm): 2-1/8, 5.4
Depth (in., cm): 9-5/8, 24.4
Frequency response: 25Hz-200Hz, +0, -1dB
Input sensitivity (high level): 250mV-10V
Input sensitivity (low level): 125mV-5V
Signal-to-noise ration: >95dB, a-weighted, re: rated power
Active crossover: 24dB/octave, variable 50Hz-200Hz, low pass only; 24dB/octave high-pass subsonic filter fixed at 25Hz
KICKEQ boost: Selectable to +12dB, centered at 40Hz
12dB/octave subsonic filter defeatable @ 25Hz
NOW i want to get TWO 10's compVR subs to connect to my amp! soo 2 tens!
do i want to get the 2ohm subs or 4ohm subs? they come in two differnt options..
no idea what to get.. just someone tell me please haha! i dont even know what ohm's are haha!
but i just want some good bass! strong bass! clean bass! haha
SO 2ohms or 4ohms subs to go with my amp?
THANKS!
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
two dual 2 subs
HI! wassup all~~~
Model: ZX750.1
Class: D
THANKS!
You'll want 2 dual 2 ohm subwoofers... Use wikipedia and you can learn a bit about resistance and ohm loads if you haven't taken physics yet. It really isn't all that complicated and there are tutorials on Rockford fosgate and JLaudio's websites to teach you how to wire them up. Shoot me a PM if you need any advice and I'll do what I can for you //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
etl45
etl45
Seattle, wa
etl45
