Firewall hole...
i couldnt find a spot and didnt feel like drilling so i just ran it through my door gromment and into the cabin that way. you can see it when the drivers door is open but it works lulz
Hopefully your not pinching it within the door lol. Might blow something.
nah it's not being pinched, it's fused so it won't damage anything. i do want to get it put thru the firewall one of these days lol
How can you not find a place to drill? your firewall should be a big hunk of metal.. with alot of room to drill a hole in
don't be lazy, fix that shiz. if it shorts out it can damage your amp, the fuse only protects the battery
I have dealt with several blow through sub setups over the years. Forget just trying to extend the port into the cab. All that you will hear in...
You're probably right. I have two Taramps smart 3 amps and four 10 inch CT sounds tropo for bass. I'm actually going to only install one of the...
14
Wingsfreak9
Wingsfreak9
Howell, MI
WhyUmad
audiobaun
    May 19, 2024
    May 19, 2024
