finishing ideas....
inapontiac
heres a picture of my current setup.
and i was wondering what you guys opininon on finishing the front of it with. n e suggestions/drawings, please let me kno.
I'd fiberglass those port openings so they're an extension of the dash...not so much an eyesore sticking through it. as for the front...bedliner, carpet, paint, maybe a fiberglass cover...anything is better than how it looks now....
how does bedliner come? i dont have the equiptment/time/money of steve meade and what he did to his honda but that does sound like a great idea. also, removing the rear glass, is that something that can be done from home?
you can make a cosmetic panel for both the port as well as the subs, for the subs you can cut some rings the size of the basket outer diameter with some meat on them over .75 should be fine for the width of the ring. then make a panel that will follow the outside edge of the trunk brace. and the walls surrounding the area. then glass the mdf rings to that panel. apply enough layers of fiverglass to make it solid sand to perfections the paint, cover in vinyl, carpet what ever. you can use the same technic on the ports.
not really, unless you have the patience to put it back on, as well as the tools to do so.
idk what its called, but you need some type of adhesive silicon compound.
inapontiac
inapontiac
Richmond
iamamp3pimp
michigan born
    May 14, 2026
michigan born
    May 14, 2026
