apeek
I'm going to be building a box for my phoenix gold octane-r12...Going to be using 250rms watts. No limit on box size... This is going to be a SQ box, so I was thinking 2.5 cubic feet, tuned to 30hz. Does that sound like it would work? What would you run?
here is some specs RMS Power: 250 WATTS
Max RMS Power: 250 WATTS
Maximum Power: 500 WATTS
Impedance: 4 OHM SINGLE VOICE COIL
Sensitivity: 91dB
Diameter: 12"
Mounting Depth: 6 1/2"
Cutout Diameter: 11 1/6"
Vas (liters): 118.8918 LITERS
Fs (Hz): 22.346 Hz
Qts: 0.42
Xmax (milimetters): 25MM
Thanks!
Sensitivity: 91dB
Diameter: 12"
Fs (Hz): 22.346 Hz
Qts: 0.42
Thanks!
