Finally....My new install build
I got such a good deal on these things I could not resist....
got the BPX 2200.1 and the GTO 75.4 inverted on the ceiling
above the rear seats.
now I got room for the 4 woofer enclosure and things are starting to
look alot cleaner...when I strip the interior in the spring to Dynamat
I will be replacing all the power wire and RCA's as well as adding
a capacitor, digital distribution block and a second battery
You may have touched on it man, but aren't your amps going to get super hot mounted like that with the heat rising and having no where to go? Or are they going to be able to stay cool since it's in a large vented space? Sorry if it's already been asked but Reading
the heat sink on the JBL amps wraps around the bottom of the amp
and up the sides and the amp rack is cut out behind the amp..there
is more than enough airflow around the heat sinks to keep them cool...
when inverted the heat rises into the heat sink away from the circuts
I was having problems with my GTO 75.4 getting really hot when it was
mounted flat on a carpeted surface and with the way it is set up now
it is not a problem..it stays alot cooler
THUMPPER
Pound That Sound
THUMPPER
Salmon Arm BC Canada
THUMPPER
ThxOne
    May 13, 2026
