Not daily. Don't wire for fire. You're going to want to wire the coil of each woofer in series. This will give each woofer a 4 ohm impedence. Then parallel them all together
for a 1.3333333333333 ohm final impedence. Your amp will thank you.
Not daily. Don't wire for fire. You're going to want to wire the coil of each woofer in series. This will give each woofer a 4 ohm impedence. Then parallel them all togetherfor a 1.3333333333333 ohm final impedence. Your amp will thank you.
