Final ohm load of 4 dvc 2 ohm subs
i thought you can wire this to .5 ohm? because if you wire 1 dvc 2 ohm sub it can go to 1 ohm, 2 dvc 2ohms subs wire to .5, so 4 should also end at .5. i may be wrong tho but i thought it work that way
If you take both pairs of subs that are at .5 and wire them together, you cannot end up with a .5 load, it would either double it or half it, which is .25 or 1
You could say each pair of subs wired at .5 would equal to a SVC .5 ohm sub, and if you wired two SVC .5 ohm subs you'd get 1 ohm or .25 ohm. Remember, you'll only have 1 set of + and - minus wires for each pair wired to .5 ohm.
you lost me this parts right(because if you wire 1 dvc 2 ohm sub it can go to 1 ohm, 2 dvc 2ohms subs wire to .5) so why do you think it would remain .5 when you wired in a second set? it would half the load again leaving you at .25
oh i was thinking if you wire 2 dvc 2ohm subs to .5, then use the 3rd 2ohm to wire the load up then the 4th would wire the load back down. but ok i learned something new today lol
southport2014
southport2014
Indianapolis, IN
goingdef
