Fighting with ford factory DSP, possible junk sub.
Here is a guide to FORScan for those interested in modifying their Ford stereo'shttps://docs.google.com/document/d/1-8dKaS_Spu4Zw4hV_CrKC4tLoP9G8yejqegF1wxIqxY/edit
ODB connector-
Cheap wired ODB connector
https://www.amazon.com/bbfly-BF32302-modified-Windows-ELMconfig-Forscan/dp/B01N9R9QS2
Wireless but more expensive ODB connector
https://www.amazon.com/ScanTool-426101-OBDLink-Bluetooth-Professional/dp/B006NZTZLQ/ref=pd_bxgy_263_img_3?_encoding=UTF8&pd_rd_i=B006NZTZLQ&pd_rd_r=TR0KHKDH963QW32CVMNJ&pd_rd_w=qQU02&pd_rd_wg=nMV8u&psc=1&refRID=TR0KHKDH963QW32CVMNJ
This worked on my 2017 F150 and 2017 Mustang
Variable Line Level Preamp Outputs From ACM (for adding aftermarket amp without sound clipping)
ACM727-01-01xx5Axxxxxxxx
ACM727-01-0200xx
APIM7D0-01-012xxxxxxxxxxx
Source
https://www.f150forum.com/f118/2017-low-level-acm-reprogram-audio-build-372285/
This works for 2016 and older (note the xx59 instead of xx5A)
This mod can be done with FORScan w/ODBLink MX Adapter:
727-01-01 xx59 F8x8 xxxx - Enables Line Level with Optional Subwoofer (Aux 1) and Front Center (Aux 2) Outputs Enabled*
727-01-02 00xx - Disables Factory EQ Processing
(ACM As-Built)
* This string breaks down as follows:
5 = Variable Line Level Audio Output
9 = Enable External Subwoofer (AUX 1) and Internal Amplifier (Aux 2) (0 - Disable)
F = Disable Open Speaker Circuit Detection (w/Active FM Radio Antenna - Otherwise use a D)
8 = Front Tweeters Present
8 = Aux 1 Type: Mono Subwoofer and Aux 2 Type: Front Center
7D0-01-01 2xxx xxxx xxxx
(APIM As-Built) - APIM change required only if you have Sony DSP before completing this mod.
Source
Variable Line Level Preamp Outputs From ACM (Factory Radio) For Amplifier Upgrades
I have a 2014 SHO. Do you see a option to turn off the alternator gas savings mode? Want to have the alt on all the time.
Thanks
Sent from my SM-N950U using Tapatalk
This is from the guys over at the fusion forum but it may work on your Taurus
Battery Monitoring System:
726-04-01 (2014+ MY) xxxX xxxx xxxx
Note: I recommend disabling BMS if you have an aftermarket stereo system. Especially if your battery charge is consistently low. Alternator always on.
(BdyCM)
2 - Enabled (Default)
0 - Disabled (May lower fuel MPG)
Source
https://docs.google.com/spreadsheets/d/1yax6zfhZYj2joBczEeruqKh9X5Qhee3C0ngilqwTA7E/pubhtml?gid=0&single=true
Unplugging the hall effect sensor ring on the negative battery wire is said to have the same effect, I cannot confirm this though.
726-04-01 (2014+ MY)xxxX xxxx xxxx
(BdyCM)
Source
Awesome!! Thanks dude. Exactly what I need. I hope it's there for my sho but I think it would be.
stones
Senior member
stones
Sask
evilmonstertruk
