That looks awesome, mrray. :cool2:
If you are looking to simply smooth out the box, fill in screwholes and gaps, I've got a few installs on my personal page that essentially walk you through that process:
http://www.betteraudio.com/geolemon
Look in particular at the Projects Index, the Isobaric 6th Order Bandpass, and the Crazy Eights enclosure for some pics on the process.
Also, I don't use Bondo for that (or for anything, for that matter).
I use Plastic Wood brand (by DAP) filler, for it's good adhesion, low shrinkage, and easy sanding. It's meant for use with wood.
If body filler is in order for some project (such as actual fiberglassing) - skip Bondo brand, it's generally regarded as the worst of the worst. Use another lightweight body filler, such as White Lightning, or even Dynatron... really just about anything else sands easier and shrinks less over time than Bondo. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
