Fiberglass Question
JoeRa22
Well me and my buddy did some fiberglass for the first time in his trunk.
We finished and everything looked fine, then we realised that we really screwed up the mixing ratio of hardener to resin, like WAY less hardener then we should have used, maybe 13 drops for every 8 or 10 oz's.
Is this a really big problem, and if it is what should i do about it?
u can try using a heat gun to spead up the process. the less u put the longer it will take do at least feel some heat rising from the peice? if u do then its curing if not do a nother layer with more hardner.
Thats fine with me.
As long as it will dry at some point in time.
Its in a heated garage also, would it help if i turned the heat up?
Ok, i just checked it.
After 18 hours of drying it still feels gooey and i feel no heat whatsoever coming off of it.
What should i do?!!
This isn't my car and i need a solution today.
I would mix another small mixture of resin with a high mek content like 3% and brush it over quickly . should help activate the under layer. still might take 24 hours or so to dry though. I did the same thing my first fiberglass project. took 72 hours to dry LOL.
Ok i mixed up a batch with about double the needed hardener and used that to lay one more layer of mat.
I let it dry for about 7 hours and it felt pretty hard, my buddy needed his car so we had to take it out.
It ended up poppin out pretty easy and held its shape nice.
Thanks to everyone that replied, i'll post some pics when im done.
JoeRa22
JoeRa22
Chicago
spoonraker
vegang
vegang
