fiberglass enclosures
Go to http://www.selectproducts.com They sell everything you will needto fiberglass. nd alot of cool tools that cut the time in half. Also they hve really good videos that you can buy that will show you step by step on how to do it. To answer your question about thespeakers. you have to get mdf rings and angle them how you want before using the fleece.
Originally posted by justchillin
Also, how much more difficult would it be to make the enclosure see-through (with glass/plexiglass on the front so i can see into it??? Ideally i would like to do that and have a neon within the enclosure...will this affect sound quality??? [/b]
well to be honest i was thinking about doing somthing similar to that like a plexi glass see through window and putting a black light in the box w/ the Alumapro Alchemy's...i think ive decided on them...i think it would look cool w/ them being white and all....also i have been thinking about using chicken wire as my mold for the first layer or so of the box....anyone think that'll work real well??? or is there anything else that you would recomend using??? also how do you think a custom ice chest in the trunk would look??? cause i go to the lake alot in the summer w/ my wife....kinda thinking that would be kinda handy and sweet looking as well....any input is appreciated......thanks
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
4K
No reason you couldn't just glue a ring of plywood up under there then paint it with some bedliner or plasti-dip or similar to keep the elements...
6
THIS IS THE SAME AS THIS: One coil + to the other coil - (on each). The other + & - to the terminal block. Terminal blocks wired straight...
i see, good to know At least. that means i could squeeze out more air volume indeed. bit of a crude design but so far was thinking of roughly...
Yeah. Same thing here. The under seat box I did for the 8s was 325$. He’d already wasted that much with 2 prefabs that sounded like ass.
6
MikeofTulsa
Moderator
The one and Only!
MikeofTulsa
Tulsa, OK
MikeofTulsa
