Fiat Stilo by _Dejan_
Amplifier for sub. Audison VRx1.500 + SPL TUNE KIT
2400W RMS @ 1ohm (AB class)
panels for tw(not completed):
Place for headunit:
And working plugin for Centrafuse for TPMS device
Radio installed:
Cables for CarPC
Im change original antenna with new one
Original:
New:
Continue with boot:
And how look panels for tw in car:
New blinkers:
Before:
After:
Test box for subs:
If will be good I will build new one(nicer one) //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Here is link to youtube when I have been in our national television //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifLINK
And yes they are make mistake in Centrafuse name :thumbdown:
Im buy new AGM battery for car //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Then Im connect battery with my sistem...
And thats all for now //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Jesus, one of the nicer installs I have seen so far. Well more equipment, then install as it looks as if you are not finished.
Also your English is better than a lot of members from America. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
That includes me, lol!
Hi,
No, Im not finish it yet, I must put fans in double-floor, add socket for filling battery, build new case for subs(First I must try it how work in bass-reflex //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif ), I must change disc in carpc from SATA to normal ATA(I have booting problem and problems with connector), I must repair mask for LCD(start "cracking" because of vibration from subs)...
About my english, I use dictionary for assistance //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Bye, _Dejan_
Hi,No, Im not finish it yet, I must put fans in double-floor, add socket for filling battery, build new case for subs(First I must try it how work in bass-reflex //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif ), I must change disc in carpc from SATA to normal ATA(I have booting problem and problems with connector), I must repair mask for LCD(start "cracking" because of vibration from subs)...
Bye, _Dejan_
Thats cool, plus you will never be done, as it is an addiction. I have been in the audio field since I have been 16 and I am 31 now and have had over 30 different vehicles from cars to trucks. Had a sound system in most of them. So not sure how long you have been into it, but from the looks of it, you seem to know what you are doing, so I would imagine you have been doing it for awhile.
You seem to use different words than what we would use. Such as when you use the word "case." Do you mean enclosure? That is what we use. Also not sure when you mentioned "Bass-reflex?"
Also if you are cracking your trim panel from the bass, then jesus, you must have some extreme bass going on in that little car.
I am American and I sometimes have to break out the good ole dictionary, lol!
_Dejan_
_Dejan_
Slovenia
SourDeez
