Fi Q 12" *short review* pics, vids inside
3.5-4cuft. 30-32hz mines 4-32hz and still hits low as hell how much power are you runnig jigga
I should be ordering the sub soon. Power will be either 600-750 @ 2 ohms or 1400-1500 at 1 ohm. The confusing part is I don't know which VC config to go with until I know which box brings the best out of the Q.
If your running lower power go with a bigger box and smaller if more power. Mine likes the 4cuft with around 650watts. If your going to run 1400-1500 watts 3-3.5 or sealed
Hey Asaner, if you are not satisfied with this Q, let me know and Ill take it off your hands.
BTW did you have the enclosure firing up while listening or just for the video??
If you did, then try having it face rear, and slide it back a little closer to the hatch.
Would it be possible to make the ported with dual ports? My setup is conccentrated towards show so I need it to look good also. Single port on the side kind of ruins the look.
We already saw what happened to it before lol. Started one before but it gt lost in the translation. My bad. Anyways, This is the first valid vid of the Q in full action. Props to the OP.
Hmm, perhaps a little 12 test sessions is in order... Too bad I already sold the XXX.
asaner85
asaner85
Chicago
dB Dom
