1) Xmax is not max excursion.The FI Q xmax is 27mm Thats about 1.07 inches, if he got 2 inches out of it, or even close to 2 inches thats alot more than he paid for
100 ac voltsFirst off, it took 10k for a short period of time, just before the cone detached. It wasnt' going to live long enough to really test it with 10k, it failed mechanically pretty fast I'd imagine. Secondly, they could have been right on top of an impedence spike, 10k at 40 ohms anyone? Third, in a ported box you'll never see never see full output hardly ever, that's the ENTIRE point point of a ported box! That's why you let the ****ing enclosure do the work for you. A quick model will show you that getting full output at certain frequencies in a ported enclosure requires WAYYY to much power to be reaistic. Increasing excursion by adding power to a ported box adds a good chance to have the sub unload on you, without a huge audible benefit, especially for daily. If you call a 1000 watts of power "small", a SQ oriented sub probably isn't for you, in which case you DO have a different goal for your system than the thread starter did, since he wasn't looking for a 1 note wonder, and was pleased that it blended with his fronstage.
I dont see how he got 40ohms outta that???100 ac volts
50 ac amps.
i dont think that is quite 40 ohms as you say //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Actually that wasim the man - D4L
Im definately not done playing with this badboy! I will try it sealed in a 1.78cuft before sub disp. and also in a 1.2cuft sealed and let you guys know how she sounds.
The lowend is there, no doubt about that. Im sure I can bring out more lowend with a lower tuned enclosure. The Q gets loud, but not crazy loud.
In the same enclosure, and using the same amp, My 12" HC hybrid gets pretty darn loud and very LOW. But you just cant comapare it to the Q's sq.
Im also going to put my 12" Ava in that same box. This should be interesting!//content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
