fi BTL 15 vs Audioaue HD3 15
with the SQ id go with the hd3..but if ur looking for mainly spl then BTL..
I bet the hd3 could hang with the BTL in STREET classes for spl use too //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i just cant pick between the 2 :~/ i have read a bit more bout the BTLs (loaded) i do that audioque is close to DD subs. iam just want'n a single 15 setup that will out-paly(all around louder, not just peak louder) than current system(4 jl audio 12w3v2 sealed 5.75cuft)
flip a coin but you all know what my choice would be //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
i would personally go with aq... but thats me...
yes the hd3 is alot like dd's 9500's...
HOWEVER... it does not have as good as efficiency at disbursing heat. so it can only take so much power past 4kw...
and it has different suspension...
other than that it is built by the son of the owner of dd ( jassa)
thats my 2 cents....
both of these subs are more on the spl side of the spectrum...
many have people have said 2500RMS Loaded BTL
theres also that 2 yr warranty on the AQ, although you will probably never use it, and none on the BTL...but flip a coin...
this exact comparison has been mentioned at least 3 times already...one by me //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif so searching would be a good thing...
1x 15" or 4 x 15" either way your gonna suffer in the sq department, jl subs sound good.and if its just 1 x15 spl will be down as well //content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
just wanted to comment on this- it is WRONG. owner of audioque is the father of owner of dd, not son... other than that, im sure jmanjr will chime in soon, telling you to get audioque, and contact jerimiah about the box, yada,yada,yada... id go with audioque as well...
Id go with the btl with cooling. That driver is designed to be beaten on a daily basis.
Also the aQ's fs is really high if its like a dd which would make it less desireable for a daily
HD312 = 33hz
BTL = 39hz
am i missing something ?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
tc300
tc300
springfield,ill
JoshHd6
    Jun 24, 2026
    Jun 24, 2026
