FI BL wall or Kicker L7 wall
if so then i guess its not a true 2k. not once have i had a single voltage drop:wow:
at 100% efficiency, 2kw would be somewhere close to 166amps @ 12 volts and 144 @ 14 volts
no amp (that I know of) runs 100% efficient, and the car has other power requirements(lights, fans, ignition etc) that draw from that 130 A
i need something that bangs harder then these l7s when i wall it off.
it is possible that the L7's you have would be pretty loud in a wall. try using the equipment you have in a wall....then if you want louder you can change the baffle on the enclosure and cut new holes:D
anj46907
No Longer Truckin
anj46907
Bradenton, Florida
dman4486
