Few more Aero questions
When you use Aero ports, do you make the box the recommended sealed or ported size before adding the ports? Is 2 3" ports (about 13 inches long each) big enough for 2 Memphis PR 10's, or will there be port noise?
do you have the 3" ports? i'd do a single 4" port instead, which is about 12in^2 of port
I asked because I thought on The Guide to Aeros that he was saying something about making a sealed box? The port will be external so I don't think I need to worry about port displacement?
Why did you guys stop responding? If I use PVC, how long do I make the length? Using the PSP calculator how much length does that to the pvc since it has no flare?
Bass911
Bass911
Dallas,TX
Bass911
