Few amp Questions
  • 1
TheJuggla1
Surrey BC
I am thinking about possibly buying a 18" Kicker Solo X, I hear about 4k is about the max for daily, so that is what I wanna aim for. 4k Seems reasonable, wont be THAT hard to fully power, but still 4k is A LOT.
So I wanted to run this off a Kicker amp since I can probably get a super deal on it, but the only problem with kicker is they only offer 10,000, 2500 and 1500 watts, as their top 3 Mono Amps. I don't want to put all the money into a 10,000 watt amp for only the off chance I might actually pump it to the max?(And also isn't their warhorse like a couple grand?)
I wanted to know if i can Run 2 amps(Most likely the 2500 and 1500 Watt one models) together to power one sub?
If not, what is a good amp that can put out 4k Watts?
One other thing I would like to know is I hear having your amps maxed out a lot can be bad, I am wondering if there is a way to say limit the amp(s) from putting out more than 3800 Watts into the sub, since that gives them a little extra room so they aren't maxed out, without having to ohm meter it.
Rest is just if you are wondering why I choose kicker.
I choose kicker because the store I built my rep up at has kicker as one i guess you would call it 'main' brands, they have a nice kicker booth separate from all the other speakers advertising pretty much all their subs speakers and amplifiers(Besides the 18 square and warhorse) so I can usually get even a better deal if I buy kicker.
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
The bigger the gauge number, the smaller the wire. 8awg would be smaller than 7awg. Yeah, go with 4awg. 7awg sounds like it must be for an...
I found this, can it be done with snapon modis ultra scanner which i have...
Two subs, same issue, two LOC's same issue, seems to me that there is an issue upstream. Have you tested the amp disconnected from the signal...
305
TheJuggla1
TheJuggla1
Surrey BC
TheJuggla1
