um someone said they dnt work good 2gether
then are you saying iraggi doesnt work with standard agm batteries? i can run off a whole list of alts that work really well with kinetik. i hear people call out XXX alt company and xxxxx alt companies all the time. most impotant thing with an aftermarket alt is installation and having the propper parts per vehicle that it is going into. that way it kicks out power at idle rpm, doesnt undercharge nor over charge.
http://www.powermastermotorsports.com/998_16VCHARGERUserGuide.pdf read page 4 and 8
quoted from page 4
"Compatible With All Lead Acid Batteries Including AGM
Lead acid batteries have different charging requirements based on their specific design. Flooded and maintenance free batteries require a higher voltage per cell than do sealed valve regulated types such as AGM and gel-cell batteries. Overcharging will reduce the life of any battery as sealed valve regulated batteries are especially sensitive to high charging voltages and overcharging. Overcharging an AGM or gel-cell battery will cause permanent damage. The proper charging level can be selected by means of a battery type switch on the front panel."
that charger works on a kinetik battery.
quoted from page 8.
"Electrical Specifications
Nominal Battery Voltage 12VDC or 16VDC (user selectable)
Operating Output Range 4.0 – 20.0 VDC
Charging Technique 3 stage
Rated DC Output Current 2/15/25 ADC (user selectable)
In the “Flooded/Maint. Free/Deep Cycle” mode..... 12V......... 16V
Absorption Voltage............................................. 15.0VDC ..19.8VDC
Float Voltage at no Load ....................................13.3VDC ..17.7VDC
Maximum Output Voltage ...................................15.3VDC... 20.3VDC
In the “AGM/Gel-cell” mode....................................12V ...........16V
Absorption Voltage........................................... 14.3VDC .......19.0VDC
Float Voltage at no Load ..................................13.2VDC....... 17.6VDC
Maximum Output Voltage................................. 14.6VDC....... 19.3VDC"
