Southeast Region Feb. 18th Comp. in Carrollton, GA
AR,AL,GA,FL,KY,LA,MS,NC,SC,TN,VA
here ya go Sam
thanks man... i wish i recorded my own run, my rear view mirror broke off from the windshield as soon as i unpaused it...
yeah, the amp made a huge difference this time around, but i also had my EQ set all the way negative last time... oops... edit: had it set to flat today
i have it wired up at .5 now and it will make the sxs stink pretty quick. i just keep the sub level below -10... mm3000.1's are beasts, couldn't be happier with it, thanks again...
i plan on coming to tifton, and i'll see if the local shop here will let me stick up a flyer...
If you are happy you should post a little review in the review section. To many people think the autoteks are just cheap copys of Hifonics amps.//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
your eq would have made no difference because when i test a vehicle i keep going with the volume until the meter stops ganing,and thats the way i metered you today and last time,all the eq does is make the meter get there fater without having to turn the volume up more,but when you running testones its better to have everthing flat.
ah, okay...
i'll have to think of something intelligent to write and post up a review sometime, haha... i still haven't even messed with it at all, can't wait to get off work tomarrow and put a hurtin on those subs //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
squeak12
squeak12
Thomaston, GA
matrxx dude
