What ratings am I looking for in a sensor?That looks sweet for sure. Have you thought of adding a temperature sensor so the front fans aren't on unless needed.The rear fans will probably exchange the air in that small enclosure pretty well. I know they aren't terribly loud but can be a small annoyance at low volumes. Just a thought...... Very nice work.
Does Parts Express accept Paypal?or....
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=330-070
cheaper //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Freckleface.verrry nice.. what kind of window you got there? im looking to make a false floor/hatch an ill be getting some cold cathode lighting but im not sure which kind of glass to use.. i think plexi is to expensive for me
wait is it necessary to use a resistor when running 12v computer fans?just have the fans run all the time.
if you need to, pick up some 10W 10Ohm Ceramic Resistors from Radioshack...
if those are computer 12v fans, then they will be running faster then they should anyway... throw in a 10W 10Ohm ceramic resistor and it will drop the voltage to the fans by about 3 volts. I did this to make my 8cm fans run at around 10v instead of 14.4
Yes they are computer fans, and yes they run fast as a MF!!!if you need to, pick up some 10W 10Ohm Ceramic Resistors from Radioshack...
it's not necessary, but running them at 14.4v instead of 12v will definitely speed them up, which means that they will not last as long. Fans are usually rated at how many rotations they will go before the motor burns out. Usually in burning out, the fan gets louder, which will not be good especially if they're already louder than normal because they are going faster.wait is it necessary to use a resistor when running 12v computer fans?
and great site privatepastry. ima get my polycarb for my false floor there. cheap stuff.
