False Floor for Tahoe
or another option would be to use a solid state relay instead of a mechanical relay, they do not suffer from the "back emf" that the mechanical ones do
~Magick_Man~
edit: no it has nothing to do with the fans, it is just about the relay possibly messing up your headunit when turned off, the diode prevents the negative voltage from going into the remote output on the hu
that removes the possibility of anything happening
edit 2: haha you were too fast for me
~Magick_Man~
WAIT...
this means that...
if i have the remote wire from my head unit wired through a relay to ground, to limit current on another wire ran perpendicularly through the relay, this could cause problems?!!!!?!
the diode attaches to the control side of the relay, when the field collapses a negative voltage pulse will be sent from the relay up whatever wire is supplying it with the control voltage.
in our cases this would be our hu.
that negative voltage spike *can* damage the internals of sensetive electronics.
with the diode installed when this negative puilse goes up the remote wire it will be sent directly to ground so not to cause any problems
so it is just for a measure of safety, odds are nothing would happen if the diode wasnt used but why would you want to risk a several hundred dollar hu for a
that would be just silly.
~Magick_Man~
whoa whoa.. now im all confused.. i bought one of those $6 automotive relays at radioshack and will use it for proly 4 fans and 2 cold cathode tubes..
how do i figure if im in risk of damaging anything.. these big words are killing me right now aha
with the mechanical relays (like the one you have) you should use a diode of some sort to protect yourself. you might be fine even without one but i dont think it is worth finding out the hard way since the diodes are not expensive.
or
get a solid state relay and use that, but they tend to be a litle more expensive (around $10) and generally cant handle as much current
either way will work just fine, i am going to go the diode route for my car when i get my stuff all set up because i already have a mech relay and dont feel like taking it back //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
~Magick_Man~
BCONNELLY
SQ Budda
BCONNELLY
RALEIGH, NC
BCONNELLY
