fading at high volume
Check ALL of your connections 1st, but I would try another HU if all checks out OK to narrow down the issue the fastest //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
yep exactly what he said. There may be a connection thats becoming loose upon high vibrations, and ruling out the headunit would be a great place to continue
I will double check connections. I doubt its hu since it only does it on the front left side. maybe connections behind the speaker?
- Yes, Check EVERYTHING //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
that is going to be a b*tch. =/
LOL I hear ya there, maybe you have a friend who has a known to be good working HU laying around so you could just swap the HU FIRST and see what happens then before you have to really start tearing sh1t apart? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
im running 3sixty.3 off my stock nav. so trying a diff hu is almost impossible unless I wire one up just for this. lol
Happens to me occasionally. I believe the culprit was my amp, but it's 20 years old lol... You probably have a loose connection like mentioned
thanks for the input. im running off a fairly new jl 600/4. luckily, like with you, it only happens occasionally. but still annoying that I don't know when or why.
ahh, ok then - gotcha... Yes then, in that case I'd start checking over ALL of those connections everywhere possible then... Has this been an issue since all of this was first installed? or did this just start happening out of the blue AFTER it was working properly at one point?
robertoyoung08
robertoyoung08
bay area, ca
NIHL8ION
