Fade not working correctly
  • 4
McOpCo
I don't know why but when I fade my head unti a pioneer 8100 NEX to the rear speakers all sound goes away. When I fade it back to the center or all the way front sound is fine in all speakers. So it's is like the head unit thinks the RCA's plugged into the rear channel are actually a additional 2 channels of front speakers. Left to right balance works fine all four speakers work fine. I am running a pioneer 8100 nex and a JL audio HD 900/5. I ran all new speaker wiring to the speakers so this is confusing me. I am assuming it is some setting I am missing in the head unit as that is the only thing I can think would explain this.
Thanks for any help.
make sure you aren't running it in network or any other mode that isn't standard.
this is going to sound dumb... but read the manual lol
I'm an idiot. I hadn't even looked at the AMP control panel. Took off the security plate and guess what???? Amp was in 2ch. Mode. Switched it to 4 and was in business.
I had two alpine sw10dvcsseries wired at 1ohm to hifi1000D mono amp. I thought i did the math right when adjusting controls. But apprently quite...
810
Figured it out. For some reason my rca cables would work in everything but the new head unit. I quickly tried a spare set, and that fixed the problem.
There isn't much it can be. Pull the amp turn on wire out of the amp, and just run a wire from there and touch the distro block will activate...
Its lasted 19 years thus far. Could be something as simple as a wiring connection as stated. Nothing in electronics last forever. Its had a great...
McOpCo
McOpCo
Fort Wayne, IN
keep_hope_alive
    May 18, 2024
    May 18, 2024
