factory exploder help
pbnj22
Duluth MN
how do i take out the factory double din radio in a 2000 ford explorer xlt without mach audio...
i have read online that there is 4 holes that you need something small and long, like a nail or an alan wrench to poke all 4 spots at the same time and the radio should pop out.. i cant seem to make it work though. anyone done this before or know my problem??
its hard to poke 4 holes at the same time //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i have read online almsot every ford older than 05 ish needs this. anyway around this.. i would think i should be able to use 4 nails or 4 alan wrenches or something but i cant seem to get all 4 springs pushed and get a good enough grip to pull the radio out... theres gotta be a work around iw ould think.
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Then you need what I listed. You also need to find out if your Honda Element has an OEM amplifier or not. And if you have steering wheel controls...
975
pbnj22
pbnj22
Duluth MN
pbnj22
    May 18, 2024
    May 18, 2024
