Sold F/S Revolution design RD 3250.1 Class d powerhouse 3000W rms @1 ohm
ampjunkielikeme
550.00 shipped to the cont usa....firm no trades
this amp is in 100% working condition...comes with the remote bass knob..and factory box....it will also be double boxed to protect the amp...
its in near mint condition...i would give it a 9 out of a 10 because it does have a couple very small scratches...nothing major....
functionality- 10 out of a 10.....it works 100%
F.Y.I.- i bough this amp blown , and i rebuilt the power supply with all new gate resistors, date code matching power supply transistors, new 949tl pwm ic chip, and few other small transistors...
i then sent the amp to chris at db-r to finish the repair and get a clean bill of health. plus to make sure the amp was going to be reliable after the repair....it passed the load test , and its now ready to pound some subs to death....lol
Specifications
RMS power, 2 ohm linkable/dual mono 5600w x 1ch
RMS power, 0.875 ohm mono 3750w x1ch
RMS power, 1 ohm mono 3000w x1ch
RMS power, 2 ohm mono 1500w x1ch
RMS power, 4 ohm mono 750w x1ch
Signal to Noise Ratio >100dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 300A(external type fuse - not included)
Input Sensitivity 200mV to 6V (+/- 5%)
Digital class-D linkable mono block amplifier
MOSFET PWM power supply
Daisy-chain through output RCA
Double sided through hole epoxy PCB
Stable into 1 ohm and 2 ohm parallel amplifier connection availability
24dB/oct variable crossover
Variable subsonic filter
Variable bass boost
Variable low pass filter
Variable phase shift
Efficiency : 86% @ 4 ohm, at 100Hz
Multi-way protection circuitry (Thermal/over current/speaker short/speaker dc protection)
RCA line input
Tested voltage & THD : 14.4V & less than 1% THD
Operating voltage : DC 10V~18V power input- 2008 models
Wired remote controller
MSRP
$1399.00
this amp is simular to a sundown saz3000d
ampjunkielikeme
ampjunkielikeme
nash, tn
mobileLcx
