Extreme low idle voltage. New alternator
no i had the same thing happened to me. it must be the way u put you alt, the ground connection and such, trust me i had at idle like 12v. had to be ur connections? also what alt u have can play a role too
The battery is about 2 months old. I got the best one at oriellys that wasnt a gel cell
Bad ground is a possibility. I'll check.
And did you say big 3 caused voltage drop?? I'm gonna take off my 1/0 quick and see if that helps anything
Big 3 doesn't cause voltage drop unless you did something wrong. The point of the Big 3 is to reduce voltage drop
i had voltage drops to cause of the big three. maybe your alt needs to break in?
A Ho alt should put out at least 14 volts
I know, that's why I was asking, I was referring to this guys post
I removed my big 3 and it made no changes. I tightened up all my connections to and from battery and alternator, no changes.
SourDeez
SourDeez
Fuqy u
SourDeez
