Extending 1/0 Gauge
also heard you could use ring terminals on both ends and use a bolt and nut and washers to connect the terminals but i would use a fuse holder
yep would work if you cant solder...have done it before
yea i just wonder if there is any voltage lost in doing that connection or not
if you tighten the bolt down really good you wont lose any
by far the best way to get a electrical connection with anything is soldering...just get another piece of wire...strip both ends and solder them together then tape it up
Soldering a pair of 1/0's together properly might be tough though. Best option for the average person would probably be the coupler mentioned before though. Just make sure you insulate it though...
i use a mapp torch //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
you could do it with a iron tho...just do a little bit at a time
false info.
the best way not to loose any power would twist the 2 ends together and use a copper wire nut. but that is not very attractive.
a little quote from the website
Lower on the list is soldered joints because solder is not very conductive, 7-15% conductive compared to copper.
read this to get updated on your info
http://www.audioque.com/aq/leadwire.htm
use a coupler and shrink tubing and call it a day.
-=jason=-
false info.the best way not to loose any power would twist the 2 ends together and use a copper wire nut. but that is not very attractive.
-=jason=-
that is a blatant lie...i dont care what audioque wants to tell you, solder is better because it coats the wire...tomorrow i will get out some solder and test the resistance it has
make sure to test 2 wires twisted together with a wire nut and report back to us.
the solder also gets down into the flow of current thus increasing resistance.
-=Jason=-
make sure to test 2 wires twisted together with a wire nut and report back to us.the solder also gets down into the flow of current thus increasing resistance.
-=Jason=-
im going to get 4 1 foot lengths of wire...2 will be connected with solder and 2 will be connected with wire nuts
Owners1
Owners1
Palm Beach Gardens, FL
Bender.
