ExpoSport
here's a GUI-based box tuning calculator i've been working on for a while. some may have seen it, i have it up on other forums but i finished a pretty nice sized update for it a little bit ago. pretty sure all the lil flaws and tweaks have been worked out, so i'm gonna post it here. if you dont like it, that's cool just dont use it. it's taken a long time to get it to where it's at and i'm happy with it. i'm gonna copy the original post, there's a lot to type lol.
FIIIIIINALLY!!!! finally freakin done with this update. only took 4 months lol. got a whole new slew of things. here's a screen shot of what it looks like (minus a few minor differences from this post date)
sorry for such the large size. it was hard squeezing so much into such a small box. i do realize that on some resolutions the program wont display fully on the screen. but maximizing will fix that until i can figure a better layout or a way to fix it. it should have pretty much any suggestion that was thrown my way that i could find useful. along with a couple last minute changes, like the desired net/gross volume boxes
here's the download link to the program:
Box Tuning Calculator Download
***you'll need the most up to date .net framwork for this program to work. click this link to get it***
.NET Framework
there's port cut sheets in there, but one thing i did NOT include are cut sheets on how to cut the port if it bends. there's too many different ways to cut the sheets, and the coding to go into that would be too tedious to deal with. maybe at another time down the road. right now i want to get it uploaded and not have something silly holding it back. plus, if you're building a speaker box, i'm sure you can go take some measurements in the box and see what the port should be //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i've also included a FAQ/tip sheet with it this time around. so if you get confused with something, click there first. if you're STILL confused, send me a PM with any questions. with that being said, i'm still going to paste all the contents of the FAQ here.
Box Frequency Tuning Calculator - FAQ/Tip Guide
1 - First and foremost, the RE calculator is *not* spot on, and is limited in design, so no, it will not match this calculator.
2 - When doing an oddly shaped box such as a fiberglass box, or you know the volume of a certain box you have in mind
that you want to build, put the net volume in the 'Desired Net Volume' box. This will bypass all dimensions entered
preventing you from having to guess dimensions to get a certain net volume and will allow you to tinker with different
port sizes and tuning. So if you know you want a box with 4 cubic feet of net volume, enter '4' into that box and it
will allow you to adjust tuning accordingly to that specific volume. Keep in mind that any displacement nor port volume
is NOT subtracted from this total.
3 - The 'Desired Gross Volume' box acts much like the Desired Net Volume box, except all displacements are taken into
effect.
4 - If the number of aero ports is greater than 0, then that automatically gets taken into effect and the calculator ignores
the dimensions for slot ports.
5 - The '# of Common Port Walls' box refers to how many sides of the box are going to act as sides of the port.
6 - Port length uses the box wall or baffle(s) as part of the port length. So a port that is 10" long with one baffle using .75"
wood will only need to be 9.25" long as the box wall or baffle(s) will account for the other .75". If using two baffles,
then it would be 8.5" long as the baffle will account for 1.5" of port length.
7 - Port walls are defaulted with a .75" thickness.
8 - Regular square/rectangle boxes do not need any numbers entered into the 'Height 2' or 'Depth 2' boxes.
9 - Pressing 'Enter' will prompt the program to print.
10 - Slot port area range is based on 12-16 square inches of port per cubic foot, while aero ports are based on 9-13 square
inches per cubic foot.
10 - On the cut sheets of boxes with different depths and heights, you'll notice 'H1' or 'D2' next to the measurements.
These represent which dimension is which. Here are two pictures to illustrate:
Box with one height, but two different depths: http://img59.imageshack.us/img59/8449/angledcutsheet1.png
Box with two heights and two different depths: http://img163.imageshack.us/img163/607/angledcutsheet2.png
If they do not go in the proper order, the sheet will not come out properly.
--Here is the formula the calculator uses (the same on displayed in the program itself):
http://img713.imageshack.us/img713/2590/tuningformula.jpg
--The following are links that illustrate how each ported box is taken into effect in the calculator (sub and port position can be upwards with the same effect):
1 - Port with 0 common walls: http://img693.imageshack.us/img693/6474/independentport.jpg
2 - Slot port with 1 common wall: http://img341.imageshack.us/img341/9939/bottomportbox.jpg
3 - Slot port with 2 common walls: http://img94.imageshack.us/img94/2017/middleportbox.jpg
4 - Slot port with 3 common walls: http://img246.yfrog.com/img246/6968/slotportbox.jpg
--The images were made with Google Sketchup. Free to use: Google SketchUp
should be 99% debugged (i think). but after staring at the same coding for so long, things are bound to slip by. so IF you do find something that seems out of place, PM me about it please. and only if you're certain about it. i dont want to go check something or explain how it's done several times over because it may be coded a certain way that you may be thinking differently. that'd be too tedious for me to do constantly.
hope you guys like it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
.NET Framework
effect.
