Bracing
if its a square box you will be fine but if its thin and wide you may need bracing really depends on the box shape. if you have large flat areas there will be a need for bracing
the stronger the better. never too much bracing as long as it doesn't interfere with the space the speaker needs. i built a .7 cu/ft box and it needed bracing, i like overkill
Aw hell wtf was I thinking. You should totally triple layer the entire box plus fully fiberglass the inside, like 9 layers, and then intertwine a dozen 1" threaded rods through that thang. Seriously bro that's how all the youtube know-it-alls, I mean pros do it.
This is for a .2ft^3 sealed box for a 6.5" sub, right?
MANTI5
MANTI5
Southern AZ
RAM_Designs
