experienced bass heads(system suegestions)
Is that a prefab box. Those ports seem way too small. Why dont you just get a good pair of 12's and a second amp. Then you would be alot louder. two 12's with a custom box and alot of portspace is what I would do. With your 15's your not givving the woffers room to reflect the bass back into the cab.especially if you increase the box volume. Unless you flip the box around and seal off the trunk completely. At least that what I would do.
i was thinking of flipping the box and taking out the rear seats today..
thing is i never had any luck with subs and port facing cabin
and what do you mean cut out the rear deck(you mean all the metal even where the 6x9s go???
man that sealin off the trunk thing sounds goo i want to try it but i wonder if it will be louder the way i like it
thanks everybody for your input keep it coming
4 cubes yes to small for a 18 as far as if you going to use cvr yes they will get lould I built a trunk car that did a 45 daily on 12s If you going to use cvr I would do five cubes each with nice size port but I would change to better subs really
forget the 18 idea unless your gunna wall your back seats off. which if you did that id just keep the 2 15's. you dont have proper air space currently after factoring in displacement of sub and port the box would be tiny.
lilboom
Car stereo for fun
lilboom
ca
Toone
    Jun 20, 2026
    Jun 20, 2026
