Both or solid batt, I ran 2 ody2150 (same as stinger2150) on 5k without any problems.
Stinger = 100AH $400
XS = $570
You might want to look into this Sears.com Same battery as the Odyssey/Stinger for a lot less.
What are you going to be running?
DieHard Platinum Marine Battery Group Size 31MWhich is the one you say is the same as these in sears?
all my system is on my signature.
Wrong just because they have the same case doesn't mean its the same battery. Different grade materials can make a difference. That's like saying every company that has xenon built amps are comparable to sundown because they are "same"You might want to look into this Sears.com Same battery as the Odyssey/Stinger for a lot less.
No not even close. D7500 has only a few that could come close to keeping up (kinetik 3800 and cactus cs9000 and good luck finding the cactus)So, you say that 1 of the DieHard Platinum Marine Battery Group Size 31M , will be as powerful as an XS D7500 ?
Never said 1 will be the same as D7500. Only thing close to a D7500 is a D7500, but for the price you could get more Diehard batt if you chose to go that route.Wrong just because they have the same case doesn't mean its the same battery. Different grade materials can make a difference. That's like saying every company that has xenon built amps are comparable to sundown because they are "same"
No not even close. D7500 has only one competition cactus cs9000 and good luck finding one.
No you said the diehard battery is the same as an odyssey/stinger. Hence why I said just because they have the same casing doesn't make them equal. There are many different grades of lead.Never said 1 will be the same as D7500. Only thing close to a D7500 is a D7500, but for the price you could get more Diehard batt if you chose to go that route.
Can you please share those number with us?No you said the diehard battery is the same as an odyssey/stinger. Hence why I said just because they have the same casing doesn't make them equal. There are many different grades of lead.
While the stinger's are great batteries (if you know how to maintain your batteries as your alt doesn't fully charge) they aren't comparable to the d7500. Closer comparison would be 2150 vs a d3100 where I believe the d3100 still prevails.I need experienced opinions on the battery of Stinger SPP2150 , Is this better than the XS D7500?
Thank you.
Numbers? Continue to stay misinformed. Not all batteries are created equal just because they leave the same plant.Can you please share those number with us?
