Exodus Anarchy mids just arrived.
SEASDayton
Mach5 Audio
CDT
Rainbow
Boston Acoustics
Hertz
Focal
ETC....
I have own many mids, & listen to many mids i friends setups.
I have a pheonix gold 250x2
I 125@8ohm per driver, yes they shin in the upper midrange area & the lower midbass is a beast,
Nice. I'll have a US Acoustics USA2100 for each one...should be enough. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
It has a metal cone with little break up , thats if you cross it over 2.5k
I also ran them @ 4ohms & wow the even still work like a champ.
so i decided to see what they can really do.
I hooked up a JL 500/1, & pushed them to there max, yeah i smoked them up.
i can still smell the burnt coil.
They still work, but you can hear the coil rubbing.
I only payed $45 for them.
yeah i like to play with my gear to what it can do.
I want to get them reconed but i dont kevin will have a kit for it.
how will you be running them??
8ohm a piece or 4ohm bridged?
1-50 watts into 8 ohms
2-100 watts into 4 ohms
3- 150 watts into 2 ohms
The Anarchy shine around 125.
If you are going active you will better control over them ,vs passive they where limited.
I had good resulants with 2.5k low pass, 50-60 high pass
They'll be active in the doors, one USA2100 bridged to each, so 200-250 watts available for each speaker. Crossover point will probably be pretty low since I'll be running them with some Aura Whispers in the a-pillars. I'm thinking lp at 315hz, but I'll just have to wait and see how these speakers mesh.
back in december 2009 they had a introduction price at $45.
not many people didnt want to buy because they had a low sensivity, & 8ohm.
now they are sold out.
make sure you door is deaden well.
I use 1inch Marine broad, & clay.
I had to reinforce my door panels, so they didnt rattle.
You can put these in your kicks panels vented.
They worked great in a sealed or IB
oh yeah , you can the best out of them @315hz
they should blend very with the aura fullrange.
How low will you be crossing the whispers @?
Will they be on axis or off axis?
If i where you i would play with xover pionts & slopes to get best sound for your install.
RAM_Designs
SketchUp Master
RAM_Designs
Rockwall, TX
okiedokie
