Ever modified a V6 into a V5 using brute force?
You're going to have an idle lump because you're taking a combustion out of the sequence so it will be a dead spot in the firing order. When you get the motor wound up a little, the engine speed is too fast to notice as much of a dead spot but it is still there. Not to be mean or anything, but that is definately the most ghetto and retarded thing I have ever seen anybody do. Lol I know it is basically an old junker and you just wanted to get it moving but dang.
Thats AWESOME! We are for sure from the same state. hahahahaha
Sounds like something I would do. Like the guy above me said, theres going to be a flat spot because the firing order is missing a cylinder.. once everything gets spinning quick enough though, its not noticeable. Kinda like how drag motors every 1/4 mile get so hot in the combustion chamber they actually burn the tips off the spark plugs and just keep firing.
I Like Waffle
North Carolina
R34P3R
