EQ's with both front in AND rear in?
BassAddictJ
My current alpine 11 band only has 1 input, and with my deck switch I'll be now using both my front and rear deck outputs with differing crossover points on each. I'd like to have a single 1/2 din EQ that can take in and out both signals and allow me to adjust both signals from the one 1/2 din unit.
whats out there?
**** good deal on the EQS.....i just need an half dint o fill the spot ih ave cut out that my alpine is in now
aparently the Fusion FX-45 does what I need.
still looking for any EQ that has front AND rear inputs, sub input also a plus....
Main Input Gain (it Sets The Maximum Volume Level
Achievable By The Front Controls)
* 7-band Graphic Equalizer
* 6-channel RCA Outputs
* 3 Input Sources
Adjustable Master Volume Level Control
* Adjustable Subwoofer Level Control
(front/rear/subwoofer)
* Gold Plated RCAs
* Easy Snap On Connector
* Bypass Position Notches On All 7-bands
* Blue Background LEDs
* Push IN/OUT for main or AUX
* Front Mounted Easy Access iPod/AUX Input
Specifications
Operating Voltage: 10.5---16VDC
Idle: 170 mA
Recommended fuse size: 1 Ampere
Input sources:
2 stereo RCA sources, 1 Phono source
Input sensitivity:
Adjustable from 100mVrms up to 14 Vrms
Input impedance:
Variable from 3.8 Kohm up to 10.2 Kohm
Output Impedance:
Sub channel: 510 Ohm
Front & Rear channels: 2.2 Kohm
Output Level:
Subwoofer channel: 11 Vrms@0.1% THD
Front/Rear channels: 7 Vrms@0.1% THD
T H D @ 3 Volts output: 0.003%
Frequency response: 15 - 34000Hz @ -3dB
Subwoofer frequency control range:
60 to 160Hz (@ -3db, 18dB/oct.)
Subwoofer upper cut off frequency: 160Hz
Channel separations: 68dB
Signal to noise ratio: 96dB
Center frequencies (in Hz):
45, 120, 275, 700, 2000, 5000, 14000
Control Range:
18dB (12 O'clock is the Bypass position)
75 shipped bnib full 1 yr warranty its an earthquake brand model# EQ-7000PXI
pm or email if interested.
clarion esq746 sells brand new for like 45$ and has front, rear, sub and 7volt line driver. works awesome
CLARION EQS746
* 7-Band Rotary Equalizer
* 12 dB Boost/Cut at 50 Hz, 125 Hz, 345 Hz, 750 Hz, 2.2 KHz, 6 KHz, and 16 kHz
* Adjustable AUX input sensitivity
* Rotary volume control
* 6 channel RCA outputs
* AUX input w/ source select switch
* Sub output level control
* Gold plated preamp inputs
* Gold plated preamp outputs
* Rotary fader
* Selectable 60/90 Hz Low-Pass Crossover
The Clarion eqs746 doesn't have front and rear inputs. It has switchable main and aux inputs. It does have front, rear and sub OUTPUTS.
* 3 Input Sources
* Gold Plated RCAs
Specifications
Idle: 170 mA
Input sources:
Input sensitivity:
Input impedance:
Output Impedance:
Output Level:
Control Range:
This has switchable main and Aux(1 on front and 1 in rear) inputs, not front and rear inputs. You can use the main or the Aux, but not both at the same time to achieve mixed dual input.
BassAddictJ
BassAddictJ
FL
BassAddictJ
RobGMN
    Jun 8, 2026
DEH-P7700MP.mp4
lbn.wrks
    Jun 8, 2026
