BBE setting:
BBE attempts to compensate for a speakers inertial characteristics which govern music playback. For eg,
An amplifiers output of a single frequency burst can be displayed as this waveform:
Yet, due to a speakers relative efficiency, filter networks, and physical properties of the speaker and surroundings the playback of the burst may appear like this:
With BBE on the speaker distortion of the original sound can be minimized by enhancing the original burst at the start of the waveform from the amplification stage to produce this end result:
It's not perfect, but it is a better representation of the original waveform.
The DEH-p8650MP can sculpt the amount of BBE enhancment to better suit your speaker. +BBE enhances the signal more (compensating for poor speakers) and -BBE de emphasises the effect for more efficient, responsive (and typically more expensive) speakers. All speakers have this "colouration" of sound to some extent, so BBE is good, but in the correct dosage. For example, if you can hear your speakers giving a slapping or almost doublebass output on what should be a solid bass hit, then the BBE has exaggerated the front of the waveform too much (so turn the BBE down). If you are missing some finer detail in the music, the BBE may help give more clarity (turn it up). Very rarely would you ever need more than +2 BBE.
O.K. so we need to get to the BBE screen,
goto your AUDIO setting screen by momentarily pressing the RH knob and then turning the RH knob (scrolling) to the BBE tab.
You can change the setting up or down, or turn it off altogether by pushing up,down and pressing respectively on the RH knob.
I chose the -1 BBE position, which is just shy of the standard BBE enhancement. This seems to be the best setting for my Focals, probably because they are quite efficient already, and don't need much of a push to get them going.
more info on BBE
STANDARD vs Networking mode:
That's a whole kettle of fish that you can explore later, but basically it lets the H.U. take more control of the speakers. Phase correction is the main benefit of networking, as you can now digitally change all of your crossover settings and avoid phase change errors that passive crossovers have. Generally, you have more control over your system, but with networking, you also lose the auto TA and have to work it out manually.
