EQ and crossover questions
  • 2
Cl552k4
Is it necessary to have a EQ and a crossover? Also how many Fard CAps would I need with my setup.
this is what I have:
panasonic CQ-DVR909U HU
mb quart rsc216 6.5
Infinity Kappa 693.31i 6X9
PPi 4-480 Amp
Mtx 8100d amp
2 15" Kicker L7
What EQ and/or crossover should i get?
if you wanna adjust the different tones in your music, get an EQ.
if your amp doesnt have a built in crossover, and you dont want your subs playing treble, then get a X-over. Crossovers arent 10)% necessary for an average joe system, but if you wanna cut the higher Hz range outta your subs, then you may consider getting one.
the MTX 8100d amp has a built in X-over, so no need to buy a new expensive one.
if your HU has EQ's on it, no point either, so the only thing u should look at if u wanna set tones if an EQ
12db is usually 180° out of phase if used left and right. 24db makes the full 360° phase change when running left and right. This is...
444
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
I usually cross at 80hz And as a drummer The meaty end of a kick is 40hz..like bands such as Metallica 50hz is a U2 kick
Cl552k4
Cl552k4
Marina Del Rey
more_spl
    May 31, 2024
    May 24, 2024
