Sold Entire system up for sale
mysilver02alty
Im thinking about re-doing my whole system so I’d like to see how much interest there is in my current setup. Im in south florida if anyone would like to save on shipping costs plus the last thing I want to do is show up to the post office with a 70lb sub. All reasonable offers will be considered. My email is rjb0978@yahoo.com
I don’t have a lot of references on the forums but I have a lot of great feedback on ebay(mikey3477). Will consider trades and I can put in cash of my own if I have to. I need 2 very good 12’s (dual 2 ohm) that can handle 12-1500 watts each, an amp that can push around 2500 watts into the subs, good quality amp for highs around 100 – 150X 4 watts. Set of 6.5 inch components and 6.5 inch rear coaxials that can handle around 125 watts per speaker. Any custom box builders in south florida, I need a nice box.
1 Resonant Engineering XXX 15 inch sub in perfect condition. I bought it 13 months ago new and I powered it with an Orion 1200D. It doesn’t have much play time on it because im not in my car all that much like I used to be. I never abused it not once and it was professionally installed etc.
I have a snailshell box for it. The box was custom built for that sub by a pro. Box builder on the sounddomain.com forum.
Paid 230.00 make offers and please pick it up
Sub Amp – Ampman Revolution 1500.1
It has the same internals as the RE 35.1
Specs: Note(I got these specs from a post on a different forum. If these are wrong I apologize and someone please correct me)
RMS4OHM 500
RMS2OHM 950
RMS1OHM 1600
RMSBridged4OHM na
RMSBridged2OHM na
RMSBridged1OHM na
InputLowLevel Accepts any HU voltage
FreqResponse THD
SNRatio >105db
HP/LPCrossover 18db, 50hz-250hz
SubsonicFilter 24db, 15hz-50hz (this saves my sub!! and is seperate to keep the LP filter usable for midbass and keep it from playing too high)
RegulatedPS yes
RemoteLevelPort yes-includes control/wire (comes with remote VOLUME, not remote gain, or remote volume, unlike most amps that have a remote gain knob, this amp has a volume knob that goes from 1% to 100% (had to ask to get this info) to allow you to pretty much mute it)
ThermoFan no PolarityProt yes [allows you to not have to worry about fudging up ur amp if you mise wire it..ie. pos into the neg.)[/b]
ThermalProt yes (the usuals)
ShortProt yes
DCProt yes Fuse 3 by 40A
Length 400mm Width 250mm (similar size to your amp...15x9x2 inches )
Height 51mm
DampFact 105db
SubsonicFilter 24db, 15hz-50hz (amazingly accurate, thanks to the 24db octave slope)
MaxDraw 140 clipped
Highs amp Power Acoustik TS960 100X4(nice amp)
Specs:
http://www.sonicelectronix.com/item_6196.html
MB Quart Components (PCE 6.5’s I believe but I cant remember, I bought them in an audio shop and never got the original box.)
Specs for PCE’s:
2 way component-coaxial system
Power handling: 60-130W
Impedance : 4 ohms
Sensitivity : 2.0W (90dB/1m)
Frequency response 38-32.000Hz
Crossover frequency: 2.500Hz
Crossover slope: 12/12dB/octave
Titanium tweeter 25mm/1"
Polypropylene woofer
Wet Power Coating 16 cm/6.4"
2 x PTE 25
2 x PWE 160
2 x PXE 215
MB Quart 6X9’s DTE 169
* 6x9' 3-Way DISCUS Coaxial Speakers
* Impedance: 4 Ohms
* Frequency Response: 35-32k
* Power Range: 60-140Watts
* Crossover Frequency: 4500Hz
mysilver02alty
mysilver02alty
Florida
hellraiser
