Engine RPM slowly drops @ idle! suggestions???
I dont know if this has been mentionned as I didnt read the whole thread, but a vacuum leak would give the idle symptoms your talking about
They are kind of hard to find, but you say you can hear a hiss, cheapest way to find them, is grab a can of carb cleaner, and start spraying vacuum hoses/connections. If the fluid hits the leak, the rpms should jump up (audibly to the ear)
wow!!! turns out when I got my master cylinder replaced, they either A. didnt hook up the hose connected to the brake booster right, or B, the oil from the leaking master cylinder damaged the brake booster, causing both the problem with the brakes, and the un-steady idle problem!! who wouldda thunk it!?
Any mechanic with a hint of skill.
yeah reread the entire thread it was the first thing I had him look for //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
are you one?? cause i have a really big problem now
no he don't know jack shit bro stick with me, have I been wrong yet? lolz
I was turning wrenches for a living b4 he was a bedstain //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
100% correct //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
it reduces rpm bro not increases them but you are right on track either way.
snb778
blaugh!!!!
snb778
ex. Los Angeles, CA
SicAudio
    Jun 20, 2026
    Jun 20, 2026
