i would try cleaning the battery terminals, take them off and clean the post and terminals good with a wire brush, if your lights flicker when you use any power switches or brake lights etc..wouldn't I have problems getting my car to rev up if it was M.A.F.?
(still no respenses on the ford forum) SO THANKS!
just went to get some food... and i noticed that when i pushed any of the door control buttons, the dash lights flicker real quick, not completely off, just noticeable though... is that normal on older cars? didnt effect the drop in RPM though...
first thing im going to do tomorrow is test the batt voltage, test the ALT voltage, disconnect the - and see if the car stays on, THEN i'll know if its electrical or not for sure
it does sound like I have a mini-turbo in the car when I give it some gasTo reset the ecm you disconnect both cables and hold them together for 2-5 minutes to drain the memory caps in the computer, sounds like a vacumn leak, which if it did throw a code takes quite awhile usually. and it will usually be p0171 and / or 174 lean codes, next time it does it see if it dies on its own. if it does it very well could be the IAC (idle air control) valve. the IAC being dirty or going bad will cause that symptom as well, but the vehicle will still idle in limp mode.make sure the air filter is clean and listen for a vacuumn leak, you should be able to hear it as a loud hiss or sometimes a huffing noise. an alt going bad will cause it as well so the voltage check is a very good idea whoever mentioned it.
if it was the maf the car will show a code within minutes. the computer bases everything fuel and ignition related of of it, so I doubt that is it. and they either work or they don't. but Fords are notorious for iac problems and filthy throttle body assemblies, that both can create this sympton as well.
keep us posted and PM me if you have any ?'s I have Snap-on shopkey software that can assist with weird crap and how to test components ect. It is horrendously expensive but it is what we used at my shop so....
yea but to see if your alt is properly working, dont you disconnect the - terminali would try cleaning the battery terminals, take them off and clean the post and terminals good with a wire brush, if your lights flicker when you use any power switches or brake lights etc..
I wouldnt just unhook your battery while its running, on older cars it was ok but it can cause voltage spikes that can harm your cars electronics. i dont do it on my cars personally but to each his own. BTW you would disconnect the +, when you take away the ground it will shut off.
