Engine noise
  • 6
OneArmPanda
NE
I just recently installed new components and an amp in my car and i got some pretty bad alternator noise coming through the speakers. I'm having a lot of troube trying to figure out what is causing it, hopefully you guys can help.
here is what i know:
-when I disconnect the rca cables from either the head unit or the amp the sound goes away.
-the sound's volume does not change with the volume set by the head unit, it only changes when the amp's gain changes.
- if either part of the rca touches the chassis of the head unit, the sound gets louder
The most likely culprit is a bad ground.
Double check the ground on your new amplifier.
Odds are you don't have a solid, clean connection there.
Also, when you ran your power wire to the battery, did you upgrade the factory ground there? It's easy to overlook, and could also be the cause of your issue.
Sounds like a ground loop, especially with the hokey ground. I'd ground to the body, do the big three. Run a ground from the radio to the amp's...
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Then I don't really seen the need to run a ground directly from the alt, but given your situation, it can't hurt.
24
I would run another ground wire to cleaned off metal. Sometimes there is a Metal Bracket under the dash that generally work well. You can try...
Nice looking RCAs. Most vehicles these days have quite a bit of wiring to go back to the vehicle lighting ect that run along the bottom door...
15
OneArmPanda
OneArmPanda
NE
helotaxi
