Engine Noise Caused by Radio Antena help
they used to make a noise filter just for the ant. cable. Dont know if they still do as the last time I used one was 8 years ago but it got rid of a very similar problem. but no am reception.
I dont mind replacing RCA i know they were cheap one came with the wiring kit the other was like $7 so ill try that just for the heck of it even tho i know once the antena is out it works.
And yest the antena noise filter is no more, if u find one on ebay the filter is $9 an shipping like $50 WTF
I had a similar problem with my HU. Swapped RCAs and a bunch of other stuff. Moving the ground for the HU solved it for me. Have you tried different grounds for the deck?
Bingo.
This problem is a classic ground loop issue. The antenna is grounded to the car body at a different electrical ground point than the HU and amp grounds. These problems can be a nightmare to fix, but it always involves changing the ground point of either the HU or amp or both.
An antenna filter ain't gonna help.
Sounds like a ground loop, especially with the hokey ground. I'd ground to the body, do the big three. Run a ground from the radio to the amp's...
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Then I don't really seen the need to run a ground directly from the alt, but given your situation, it can't hurt.
24
I would run another ground wire to cleaned off metal. Sometimes there is a Metal Bracket under the dash that generally work well. You can try...
Nice looking RCAs. Most vehicles these days have quite a bit of wiring to go back to the vehicle lighting ect that run along the bottom door...
15
dragonware
dragonware
Canada Toronto
maylar
