Engine Mods
Simulator
13
Chetwynd
Hey
Alright i just got my 69 Caprice with a 327ci. other then headers and exhaust (which im ordering) whats some other cheap horsepower? i am going to get a K&N filter. but this isnt enough. I need something dramastic but not to expensive becuase im on a budget.
Anyone Know if i could change my 2 barrel carbs to a four barrel if that woudl help at all and what woudl it do? Any suggestions Would Help....... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
This will not add more horsepower, but it will better use the horsepower you have. Get a new ring and pinion, something like 3.73 or 3.55. That will cost about $200 if you put it in yourself, or something like $400 to get it "professionally" installed. Like I said, this will not add horsepower, but it will better use the horsepower you have.
it won't help u use the HP better, it will just make ur car accelerate, or even just burn out better... only use higher gear ratios if you want to lose gas mileage, run ur engine harder, and the only benefiet that i can see, is lower ur 1/4 mile times... but you will lose some driveability, If ur car is just for racing, then go for 4.11's or something, but if not, then just stick w/ the same ratios that ur car came w/ factory.
Lighten the Flywheel, get another camshaft, and maybe higher compression pistons. That will bump both engine response, and HP.. best mods for a V-8 in my mind, (other than the Headers-Exhaust-Filter)
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Then I don't really seen the need to run a ground directly from the alt, but given your situation, it can't hurt.
24
I would run another ground wire to cleaned off metal. Sometimes there is a Metal Bracket under the dash that generally work well. You can try...
Sounds like a ground loop, especially with the hokey ground. I'd ground to the body, do the big three. Run a ground from the radio to the amp's...
Nice looking RCAs. Most vehicles these days have quite a bit of wiring to go back to the vehicle lighting ect that run along the bottom door...
15
Simulator
Simulator
Chetwynd
crakpotjoe
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
