Not a Starter....Dam they look like awesome batts. What makes it no good under the hood?Enersys is the parent company of odyssey batteries. Which makes stinger and the Batcap 4000 as well. The data safe batts are great. Just not as a starting battery
Thin wallsNot a Starter....Dam they look like awesome batts. What makes it no good under the hood?
Might be ok then. Not sure thoEven in cased it would still be susceptible to heat? Or is it jus not built to be a starter?
I could put it n back, but isnt there something about batts matching in order to add another?Why not just put in the back as a secondary
---------- Post added at 08:06 PM ---------- Previous post was at 08:05 PM ----------
Edit see that you will be fine on stock imho
Big 3 kit would prolly be all you needI could put it n back, but isnt there something about batts matching in order to add another?
No its too big I had 2 under the back seat of and 07 classic Silverado fed by 1/0 with the big 3 pushing an warn 8k winch about 200amp of lights and my sound system which was 2000w total. With the factory alt I could run anything fine as long as I left one of the 3 out.Urs under the hood?
